Call forwarding with KPN and iPhone 8 plus
  • 23 oktober 2017
  • 3269 keer bekeken
Cannot set up call forwarding with the new iPhone 8 plus. Tried via call forwarding in settings and also via *21*....# neither worked. Asked KPN technical help and they cannot help either... anyone knows better how to do it? `mike
Admin: topic verplaatst naar juiste categorie
Beste antwoord door Erik_ 26 oktober 2017, 15:05
Hey Mike, welcome to the forum! Do you have VoLTE activated? If so, there's a small change in how to activate call forwarding.
For direct forwarding without VoLTE, type *⃣ 2⃣ 1⃣ *⃣phone number#⃣ and finish with the green call button.
For direct forwarding with VoLTE activated, type *⃣ 2⃣ 1⃣ *⃣phone number and then right away the green call button, without the #⃣
Can you try if the second method works?
Badge +28
Hoi Erik,
Thanks for this solution.
How to disable it again?
With kind regards,
Mark
Badge +28
Hi @MarkAp, welkom!
Hieronder een tabel met de juiste opties.
