SpamCop.net opgeheven, levert problemen op!
  • 31 January 2021
  • 13 reacties
  • 2093 keer bekeken
Badge
Vanochtend wilde iemand mij een e-mail sturen, maar kreeg deze terug met deze melding:
Reporting-MTA: dns;cpsmtpb-ews10.kpnxchange.com
Received-From-MTA: dns;cpsps-ews09.kpnxchange.com
Arrival-Date: Sun, 31 Jan 2021 11:45:56 +0100
Final-Recipient: rfc822;info@*****.nl
Action: failed
Status: 5.5.0
Diagnostic-Code: smtp;550 Email blocked by bl.spamcop.net
Dit is onterecht, want dat domein komt op geen enkele blacklist voor. Dus even verder gezocht naar SpamCop.net
Foetsie dus, domein is geparkeerd (zie Wiki):
As of Sun 31 Jan 10:31:56 UTC 2021, the domain and all sub-domains of spamcop.net resolve to a domain parking service (Sedo Domain Parking).
Iemand dit ook al geconstateerd?
Maakt KPN inderdaad gebruik van SpamCop? Zoja, wordt dit snel opgelost?
Beste antwoord door Kees zelf 1 February 2021, 09:39
13 reacties
Badge
Een check op het bewuste domein geeft zelfs aan dat het niet op een blacklist van SpamCop voorkomt.
Good morning,
Our PRTG server started alerting us to the following.
IP on DNS blacklist (IP on DNS Blacklist) Down  (Error checking bl.spamcop.net, it contains an entry for 127.0.0.1 )
Also, emails sent from Office 365, some at not getting through.
watchdog.wmf.de gave this error:
Decision Engine classified the mail item was rejected because of IP Block (from outbound normal IP pools) -> 550 40.107.14.123 blacklisted at bl.spamcop.net
Appears bl.spamcop.net have not renewed their domain?
Badge
Yes it seems so…. Causing major (worldwide) problems I’m afraid…
What can we do about it, the WHOIS info doesn’t provide any way of contacting the domain owner, due to it being withheld for privacy reasons.
Badge
Well, to be honest, I don’t know.
I don’t think there’s anything we can do about it at the moment.
I posted this on this forum because I am a KPN customer. And I think the provider should undertake action, because they - KPN in my case - use the SpamCop blacklist.
Yeah I think your right, I’ve reported it to Microsoft as its causing them issues on Office 365. Will let you know if I hear anything.
Badge
Is er iemand van KPN die dit heeft meegelezen?
Badge
Wij van Wned.nl hebben dit probleem kunnen omzeilen met een fix op alle servers. Wij kregen ook erg veel klachten binnen dat klanten niet alle mail meer binnen kregen. Alle hosters en providers hebben hier dus last van. Erg vervelend allemaal.
Had a notification from our PRTG sever to say the blacklist has been removed. Does it seem ok to you guys now?
Ben de hele middag al aan het zoeken geweest en had spamcop verwijderd uit mijn mailserver. Ik zag ook onterecht mails rejected worden. Was alleen wat lastig te vinden of de oorzaak nu bij mij of bij spamcop zat. Toen ik zag dat hun webserver ook niet meer was te bereiken leek het duidelijk. Ik kon echter niet veel vinden over andere mensen die vergelijkbare issues hadden :-).
Ik heb spamcop zojuist weer toegevoegd aan de configuratie en het werkt weer goed.
Badge
Probleem lijkt inderdaad te zijn opgelost.
Problem seems to be solved.
Office 365 appears to be still having issues.
watchdog.wmf.de rejected your message to the following email addresses:
Your message couldn't be delivered because it's suspected of being spam. For best practices when sending email, refer to the guidelines found here: https://go.microsoft.com/fwlink/?LinkID=526654.
Decision Engine classified the mail item was rejected because of IP Block (from outbound normal IP pools) -> 550 40.107.8.105 blacklisted at bl.spamcop.net
