Hi there,
I have exchanged my old iTV box for a new one (as requested by KPN) and the installation of the box hangs at 85% (“Configuratie geactiveerd”) for a while and then throws an error code 562.
Closer inspection reveals that during the software installation (which works fine), the box gets an IP-number via DHCP from the Experia box (v10, H369A) but does not get one after the restart (at around the 75% mark).
I tried so far the steps 1-3 on the website www.foutcode.tv/562 to no avail. The iTV box is now the only wire-connected device to the experia box and as far as I have it under control there is no other router active that might supply a DHCP-server.
Also, as an experiment, I assigned the DHCP-supplied address as a static address to the box - no change.
iTV-box model: HMB2260
Any ideas?
Beste antwoord door OliverJennrich
