Hello,
I have exactly same issue since this morning. I have tried contact KPN by phone, but no one answer. Anyone could help?
Wei
Admin: afgesplitst en eigen topic voor je aangemaakt
Beste antwoord door Weitohome
Bekijk origineelHello,
Wei
Bekijk origineelHi
Hello,
Thanks for reply, it has solved after I submit it by your support robot dialog system.
I got a message by phone, that you solved it, then I have tried, it works.
Thanks
