Hi @sdha . How do you connect your repeater to the experiabox? My advice would be to always use a network cable.
If you connect a repeater wirelessly it won't be very effective. Also I have no knowledge of the Frits repeater so I wouldn't be able to help you with that, sadly :'(
I haven't heard from you and I'm hoping the problem is fixed! If not, please read my suggestions and otherwise perhaps contact XS4all ( they have fritzbox equipment or contact Fritzbox support )
De Kennisbank
Bestand scannen voor virussen
