After a restart of connections to router and optic fiber the internet is no bworking
That's unfortunate. Did you to get the connection working again? You can always contact our support at 0800-0402 if you need direct assistance. Please let me know if you need any more help!
Â
Thanks for the foto, it seems like the fiber connection isn't working. Are all the lights on the Genexis Box still not on? Did you check if the powerconnector is still firmly in place?Â
Yes firmly all in place. The internet is not working since 4 or more hours now.Â
Could you indicate which lights are blinking? Could you also fill out your profile? Than I will check the line from here. Â
