Wireless keeps temporarily disconnecting.
  • 14 February 2019
  • 1 reactie
  • 179 keer bekeken
Roughly around one month ago this issue started. It is completely random, some days it occurs and other days it never happens. I basically lose connection every 2/3 minutes for about 10 seconds before getting it back. Any ideas on what might be causing this?
Many thanks in advance!
1 reactie
Badge +20
Hello @whelbe That's quite annoying, ofcourse. Do you loose connection on all your devices, which are connected to your wifi? It's a good idea to use our wifi tuner. This online tool measures signal strength and is able to do some adaptations to your Experia Box. This should help you with getting a better wifi connection. Do let me know the results!
