I was in Poland for holidays but had problem in using internet. I was staying outsie of the city and the coverage for each network is different. Here are my problems per network:
- PLUS- vry good coverage and it seems that this network as preferred network. The problem is that it does not allow connection to LTE. Very often I had EDGE only even it the middle of the city! Max you can get is HSPA but still super slow.
- T-mobile.pl very good coverage. No access to this network at all. My telephone says- your sim card does not allow to connect to this network.I checked also with my wife phone and simcard- the same problem. The funny hinh is that if you have Tmobile pl card and while roaming in the Netherlands - KPN allows connection even to LTE-A (4G+). I wrote about it already on Facebook but they told me they cannot help further
- Orange- no coverage indoor- relatively good outside. Useless when you are at home but allows LTE connection
- PLAY- no connection indoor, poor connection outsie. Allows LTE
I would be grateful for help
Beste antwoord door Mpiotrek
