Toestelveilig requests unknown security code
  • 15 oktober 2013
  • 5623 keer bekeken
I have bought a new phone and have installed toestelveilig on it. Have not set any passwords or security codes. I activated a screen lock method and now when I try to change or disable the screen lock method it asks for a security code. **bleep** it never asked for a security code while I was setting it up or even when I activated the screen lock. How can I find out the security code ? Can not even uninstall the app as it requires a security code for that as well.. Don't know what to do. Please help me. Thank you.
Beste antwoord door Shugosha 15 oktober 2013, 08:56
In those cases it is best to call the customer service at 0800-0105 so their department of technical support can reset the password of Toestelveilig for you.
Badge +12
thank you very much. i will.
Reputatie 5
Badge +2
Hi Corasch,
I would like to hear from you, if everything turned out fine.
Kind regarts,
Afra
Wist u beveiligingscode wachtwoord van uw mobiele vergeten? Zo ja, wat is uw mobiele fabrikant en het model? Om uw telefoon te resetten, gebruiken Master reset code. Je kan het krijgen van een van de online verkopers zoals Unlock-Free.com   Hier bieden ze code voor oud model Nokia DCT en Alcatel telefoons.
