Beste antwoord door SjorsK
The sim code is a mandatory code that is used to "access" the sim card. Its not possible to disable it completely (I also recommend heavily against making it as easy as possible considering anyone with a sim card could effectively call 0900 numbers with your phone number if you lose your phone, which can result into extreme costs).
