Hello there, I have a KPN Sim card that is not yet activated & I don't know how to activate it, any help?
Beste antwoord door RBxx
Bekijk origineelHello there, I have a KPN Sim card that is not yet activated & I don't know how to activate it, any help?
Bekijk origineelHi
Hi
Did you buy a prepaid simcard in the Netherlands and did you take it with you abroad without first activating it in the Netherlands? In that case you'll need help from moderator
Put the phonenummer (06xxxxxxxx) and the simcardnumber in your forumprofile. Use the field "Persoonlijke opmerkingen”, which is only visible for you and KPN and save your input by pressing “Sla wijzigingen op” at the bottom of the page.
Admin: closed this topic, if you are experiencing this issue, please make a new topic and fill in your profile
Hi
Ik heb dit gedaan, hoe lang moet ik wachten?
Sorry voor mij slechte spraak, ik kan Engels beter omdat ik woon in Engeland nu.
Hi
I've brought this topic to the attention of the forum moderators. I'm hoping for a quick response.
Thank you very mucht,
I have activated the simcard for you,
Thanks,
Amar Saidik.
Hello, could you please help me activate sim card outside the Netherlands?
Hi
As the admin indicated above: “closed this topic; please make a new topic and fill in your profile”
