Beste antwoord door Marina_
Hi @Dare85 , A lot can change in 20 days. Which bundle do you use? Have you already checked if the bundle is still active? Would you like to add your mobile phone number and SIM card number to your forum profile? Then I can check what is going on.
Hi Marina 😉
Mobile number
Sim card number
*Admin: gegevens verwijderd i.v.m. privacy, toegevoegd aan forumprofiel
*Admin: data removed for privacy, added to forum profile
Mobile number
Sim card number
Hi @Marina_ can u help me to solwe this and get my speed back its the same bundlle i wait 10 mins to open 1 page
Hi @Dare85 , You put on a monthly bundle on 29-01. (KPN Unlimited Online bundle). With this bundle you can get a speed of 128 Kbit/s. Yesterdaymorning you have requested a bundle for a day with the same speed. Because of this you will not experience any difference. Last night you requested a bundle of 100MB. With this bundle you can achieve a speed of 14.4 Mbit/s. This bundle has already stopped because the 100mb is gone, but have you experienced a difference in speed last night?
Sorry my English is not very good, but I hope you understand.
Hi Dare85, no Marina this time. She is enjoying her 1 day weekend 🙂 I understand you having problems with your internet speed with prepaid. The Unlimited Online Budle is still active, because you have activated it 2 times (one for free, one for € 8,99). The 100MB with faster internet is already been used. So the speed you are getting, is 128Kbit/s. That's 0.128 Mbit/s, not a lot!
Will you want to use faster internet, I recommend to activate bundles with the 14,4Mbit/s speed (not the unlimited, but day-passes and monthly credits.
Hi @Dare85 , I can not figure out why you get such a low speed. Can you test your SIM card in another device? I wonder what speed you get with another device. This way we know whether the problem lies with your device or with our network.
If all apps are disabled, would you like to do another speed test? I'm curious if you can reach a speed of 128kbit / s
Mijn collega heeft ook gekeken naar de speedtesten. Dit zijn normale snelheden voor deze bundel. Bijvoorbeeld: 0,07Mbps wat overeenkomt met 70Kbps, wat klopt t.o.v. van 128Kbps dat het theoretisch maximum is . De snelheid wordt ook bij een onbeperkt bundel beïnvloed door allerlei factoren. Denk aan drukte op de mast of apps op de achtergrond.
Het klopt dus dat je een tragere verbinding ervaart, maar het zijn snelheden die bij de bundel horen. Mocht er iets onduidelijk zijn, laat het dan vooral weten!
My colleague also looked at the speedtests. These are normal speeds for this bundle. For example: 0.07 Mbps which corresponds to 70 Kbps, which is compared to 128 Kbps that is the theoretical maximum. The speed is also influenced by all kinds of factors with an unlimited bundle. Think of crowds on the mast or apps in the background.
So it is true that you experience a slower connection, but the speeds are part of the bundle. If something is unclear, please let us know!
