Hello
(I hope English is ok in this forum and I apologise if I have placed this in the wrong form topic.)
I have a new Experia Box V10A (firmware v6.00.13 build01) from Spark in New Zealand. Port mapping (or “port forwarding”) does not work and Spark is unable to help me as the router is new equipment for them.
Port mapping used to work perfectly on my old router (a Huawei HG659b), but will not work at all on this new Arcadyan. I am trying to access a WD Passport HDD which is continuously recording my home security camera footage.
I can access the HDD when I am inside the network. However I cannot access the HDD at all when I am outside.
Settings …
Network > NAT> Port Mapping settings
- Private IP = xxx.xxx.x.68
- Public IP = yyy.yy.yy.162
- Protocol = TCP&UDP
- Private Port = 3022-3022
- Public Port = 3022-3022
- When I am under the same network I can see the HDD using xxx.xxx.x.68:3200
- However, when I use yyy.yy.yy.162:5678 outside the network it just times out
I have also tried using Special Application mapping, but that does not work either.
I am very frustrated with this and would appreciate any help or advice!
Thank you (dank u vel!),
Mark
Beste antwoord door WH0A
