Hello!
I recently bought a smart plug (brand Wiz) that operates on 2.4GHz Wifi, however it does not work when I’m using my wifi. I tried to use the “guest” wifi, but it doesn’t work. I tried to use the extra wifi with only 2.4 GHz, but it doesn't work either. When I tried to use the smart plug with a phone’s hotspot, it worked out perfectly, but of course I cannot use it every time with a hotspot. I looked out here in the forum to see if I needed to “turn off” a firewall, but I saw that Box 12 (the one that I have) does not have that option.
Anyone can help me figure out this problem?
Thank you so much in advance
Beste antwoord door GeSp
