Bij voorbaat dank
Beste antwoord door AJG
Bekijk origineelBeste antwoord door AJG
Bekijk origineelToday, I figured out. Go to Apps → Whatsapp → Permission. It will show the default list of permission. Now choose the “|” icon at top right and select “All permissions”. Scroll and find “run at startup”. It shall only have an Ok button. How many ever times you do the okay, it keeps showing the same. But after this my Whatsapp never got into sleep mode and I started seeing the notifications. But I wonder they could have set an acknowledgement or a slide bar to know it if it is set or not. Perhaps too trivial user experience factor. There are a host of other permissions that we can set. They are not shown in the default set.Levert dit iets op? Ik ben benieuwd!
