Hello,
First of all, my apologies for the text in English, but going into technicalities is easier for me in English than missing the correct Dutch wording…
After the recent experia v10a firmware update, I noticed a few issues with my WiFi network. In particular, I now see two networks (the nominal one, plus another one with hidden SSID) being transmitted by my AP, roughly at the same power. I cross-checked this with changing the channel, powering on/off, and I confirm both are coming from my equipment, with the second "hidden” network overlapping the nominal one. No guest network is activated, and this is visible in both 2.4 GHz and 5 GHz. There seems to be no way to disable this hidden network, nor to identify it? I attach screenshots from WiFi Analyzer app below, showing the unwanted network details (I've hidden SSIDs and MAC addresses).
The main reason for this question is that my phone keeps losing WiFi connectivity at home, connecting and disconnecting a few times, and not automatically connecting anymore. This was working fine before the firmware update in July.
Also, in the previous firmware I had some similar connectivity issues, and one thing that solved it was to just disable (turn off) 5GHz radio from the AP. Unfortunately, the option seems to be gone with the latest firmware...
So I would like to know 1) if there is a justification for the second “hidden” WiFi, 2) if it can be disabled, and 3) if at least the 5GHz radio can be disabled.
Thanks, regards
Â
Â
Beste antwoord door warheart
