Hello KPN Community,
I will soon change my internet connection to KPN’s fiber optic 1Gbit. As I amonly interested in wired connection I will install the network cabling myself. The tubes are already installed in the wall so I will only install the lan cables and sockets.
I am really concerned about my ping as I am a gaming tester so I want to have the most “high performance” installation possible. I have the following questions:
- Should I use a lan cable with soft or hard core?
- It is ok if I use CAT7 or CAT6a is also fine? ( I will install 2 cables from the main router ending to two different wall sockets maximum 30m long)
- Should I go for S/FTP cable or UTP is also fine?
- Do you have any other suggestions?
Thank you all.
Beste antwoord door 19DT2120
