Hello,
I try to follow the instructions presented on your website for multi-sim activation but after logging with my KPN ID I get a: “Something went wrong… Please try again, or try again later.” message. I use proper credentials (checked that they work when logging via app). Also tried with 2 step auth. disabled - same result.
So the my question is: how do I fix this, or who should I contact to get support on this case.
Thank you,
Beste antwoord door yesiot
