I am really shocked! I am a common user and the amount of research I have had to do to eventually find out my (latest) KPN router cant handle 2.4 with 5G! I have a device which specifically needs 2.4Ghz which I can no longer use.
If anyone as a nice device or solution that can connect to the KPN router and my 2.4GHZ device i'd be open to finding out what that isÂ
Not able to use 2.4 Ghz on one device
What kind of device (brand / model) can't be connected to the 2.4GHz of your V12?
Has it ever been connected to your V12?
