Not able to use 2.4 Ghz on one device
  • 8 December 2021
  • 20 keer bekeken
I am really shocked! I am a common user and the amount of research I have had to do to eventually find out my (latest) KPN router cant handle 2.4 with 5G! I have a device which specifically needs 2.4Ghz which I can no longer use.
If anyone as a nice device or solution that can connect to the KPN router and my 2.4GHZ device i'd be open to finding out what that is
2 reacties
What kind of device (brand / model) can't be connected to the 2.4GHz of your V12?
Has it ever been connected to your V12?
Badge +15
@Joelle Z Welcome to our forum.
I see that wjb is trying to help you. What kind of device is it, and does it connect and then gets disconnected? Or doesn't it connect at all?Â
