Hi,
Been playing around with the modem (Sagemcom F5359 ) settings, mostly the Wi-Fi settings. I have quite a bit of old tech appliances and old school tech which I would like to manage on my Wi-Fi, route them all via 2.4 GHz. While on the other hand, I manage my 5GHz SSID with newer tech.
However, I noticed that it seems I cannot have two separate SSID’s for my 2.4 GHz and 5 GHz. HOWEVER, this option is available via the guest Wi-Fi access??? (which inherently simply utilizes another subnet).
I guess my question is, can I split my main Wi-Fi - as in have, two unique SSIDs; one for each x-GHz ?
I would like to manually and specifically add devices to the various SSID’s as I deem fit. Is this possible?
Or am I going to have to misuse the guest Wi-Fi option and then setup forwarding to the internal (not guest) subnet?
This seems so unnecessary … ?
Any advise is greatly appreciated
Alvast bedankt
Shaka
Beste antwoord door SledgehammerNL
