Hello, there is a field for DNS server IP in Thuisnetwerk - DHCP, however it’s inactive. Why? Is this locked on purpose by KPN?
Beste antwoord door wjb
If you uncheck the tick box DNS-proxy gebruiken on the screen below then you can enter the DNS servers to be used.
