What is the best to contact KPN way to contact KPN to solve an issue with my pre-paid card?
Bekijk origineelWhat is the best to contact KPN way to contact KPN to solve an issue with my pre-paid card?
Bekijk origineelHi
Thank you,
I have entered the numbers in my profile.
Thanks
When I check your balance, I see you have a call credit of €0,00, which explains why you're not able to make any calls. If you top up your balance, you should be able to use your card again
Thanks,
