Can't connect to websites until restart Box 12
  • 16 December 2023
  • 1 reactie
  • 11 keer bekeken
As per the heading with increasing frequency I cant connect to any website, YouTube still functions; restarting the router resolves the problem, this is happening more frequently now. I have had no previous problems for a couple of years.
This affects all the devices connected.  Most are connected with Ethernet cables, not a Wifi Issue.
Is the router at fault ?
KPN Box 12 P/N: 253843769 (Sagecom)
Thanks Andrew.
1 reactie
Badge +13
That's rather strange Andrew and specific. Do you have any other devices active in your network that function as a router? Or is there any kind of security software like a firewall or VPN active?
