Hello!
Not sure if someone has asked this before but my Dutch skills are very poor and couldn't find any similar question even after searching with Google Translate.
I have a couple of smart plugs which connect to the power outlet and can be used to switch on/off the devices plugged into it, using its smartphone app. It is connected to the Wifi using KPN Box 12.
The problem is that I am able to control the device even when I am not connected to the Wifi. Since there is no port-forwarding configured, this should be some sort of a relay over the outbound connection.
I am not sure if I am happy knowing that someone could potentially hack some relay server of the manufacturer and send messages to the plug to turn the devices ON/OFF.
Whereas I am investigating about how the device works and whether I would be able to control the device within the LAN with no Internet connection, I wanted to know if there is a setting in KPNÂ to potentially set some firewall rules to disable all outbound traffic 0.0.0.0/0 from these devices and only allow inbound from the LAN network probably on ports 80/443? Also can I configure some way to get all outbound traffic logs from these devices? If not, Is there a way to edit the route table somehow for these devices to add an extra hop to one of my other devices to log all traffic from there?
Any other suggestions also welcome.
