Hello,
I own a Helium miner which is currently relayed. In order to fix this, I need to set up a fixed IP for this device + open port 44158.
I’ve followed directions given in the forum:
- Port Forwarding → Application Configuration → Create New App Name with protocol TCP and ports 44158
- Port Forwarding → Port Forwarding - IPv4 → Create New Item with LAN Host as IP shared by Helium network linking to App Name created in step 1
- I have the device connected via ethernet so for a fixed IP, via LAN Settings, I´ve selected my device and switch on Fixed IP-Address by DHCP binding. The IP Mode changes to static.
Following these steps, the port 44158 for my device is still closed, am I missing anything?
Thanks for your support!
