Hello,
I have been working from home and since last week Wednesday, I'm having difficulties to connect to the remote server, based in the USA, that I'm using for my work. The KPN network and modem in our house is working perfectly, has been checked and rebooted by KPN a few days ago, and everything seems to be in order. But the connection problem to this remote server is still arising randomly in different times during the day, and many times it's gone for hours so I'm unable to work then at all ...
After connected to my neighbors network by Ziggo, it 's working perfectly. I have also contacted the support of this remote server in the US, and they explained the following:
' ' There is a bad Internet router (IP 87.128.239.249) in the path to the Netherlands dropping your connection and goes straight from NY to Germany and starts dropping packets on a German internet router.
This is an internet issue. It seems to only happen between a tight time frame and when you are connected to your home Internet Service Provider .
When I saw you connected from both your ISP and your Neighbors I traced the routes back to your IP address.
The results when tracing back to your home ISP was routed through Germany and had very high packet loss.
When you connected to your neighbors ISP and I traced the route back to that IP address it was routed through London and had no packet loss. "
Has anybody any idea why this is happening, and how it can be fixed??
I'm working from home since March, and never had such issue, until now..
Thanks!!
Beste antwoord door HM09
