Hi,
Sorry this post will be in English since I'm not able to speak Dutch at the moment.
I have a fiber connection installed around 15 days ago. I have been having
connection dropouts multiple times per day since then. I get interrupted at work, conference calls, etc. I've done everything, resetting KPN Box 12 to factory settings and turning off/on fiber optic box. I'm still getting the issue.Â
Here's the log:
01.01.2013 01:02:03   Info   SYS  Â
TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed
TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated
01.01.2013 01:02:00   Debug   DNS  Â
DNS name resolution failure (hengelo0.cust.kpn.net.kpn)
01.01.2013 01:01:59   Info   PPPOE  Â
PPPoE connection successfully established with user credentials.
01.01.2013 01:01:46   Info   WIFI  Â
Device <96:48:35:1A:DE:1E> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
01.01.2013 01:00:57   Info   PPPOE  Â
01.01.2013 01:00:54   Info   SYS  Â
Modem login was successful
01.01.2013 01:00:52   Info   PPPOE  Â
01.01.2013 01:00:50   Info   PPPOE  Â
01.01.2013 01:00:48   Info   PPPOE  Â
01.01.2013 01:00:45   Info   PPPOE  Â
01.01.2013 01:00:43   Info   PPPOE  Â
01.01.2013 01:00:43   Info   WIFI  Â
A WiFi device <8C:85:90:37:3E:DB> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
A WiFi device <96:48:35:1A:DE:1E> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
01.01.2013 01:00:41   Info   PPPOE  Â
01.01.2013 01:00:39   Info   WIFI  Â
Channel: (40/100) Channel Hopping initiated/Manually initiated
01.01.2013 01:00:38   Info   PPPOE  Â
01.01.2013 01:00:36   Info   PPPOE  Â
01.01.2013 01:00:32   Info   PPPOE  Â
01.01.2013 01:00:30   Info   WIFI  Â
Device <96:48:35:1A:DE:1E> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
01.01.2013 01:00:30   Info   PPPOE  Â
01.01.2013 01:00:29   Info   WIFI  Â
A WiFi device <18:3E:EF:CF:E9:82> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
01.01.2013 01:00:27   Info   PPPOE  Â
01.01.2013 01:00:26   Info   UPNP  Â
UPnP functionality has been activated
01.01.2013 01:00:26   Info   DHCPC  Â
The WAN DHCP client IP address 10.174.157.201
01.01.2013 01:00:24   Info   WIFI  Â
A WiFi device <96:48:35:1A:DE:1E> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
01.01.2013 01:00:22   Info   DHCPC  Â
WAN DHCP client (1) started
01.01.2013 01:00:21   Info   WETH  Â
WAN Ethernet connectivity has been established
01.01.2013 01:00:15   Debug   DNS  Â
DNS name resolution is now active
01.01.2013 01:00:14   Info   DHCPS  Â
The LAN DHCP Server is active
01.01.2013 01:00:14   Info   WIFI  Â
WLAN has been deactivated (.) (band : 5GHz).
WLAN has been deactivated (.) (band : 2.4GHz).
WLAN has been deactivated (KPN Fon) (band : 2.4GHz).
WLAN has been deactivated (KPN734D66_guest) (band : 5GHz).
WLAN has been deactivated (KPN734D66_guest) (band : 2.4GHz).
WLAN has been activated (KPN734D66) (band : 5GHz).
WLAN has been activated (KPN734D66) (band : 2.4GHz).
Channel: (0/40) Channel Hopping initiated/Manually initiated
Channel: (0/6) Channel Hopping initiated/Manually initiated
01.01.2013 01:00:11   Info   SYS  Â
The Modem has successfully powered up
19.01.2021 23:47:03   Info   SYS  Â
19.01.2021 23:14:49   Debug   DNS  Â
DNS name resolution failure (https://app-measurement.com/sdk-exp)
19.01.2021 22:55:44   Info   WIFI  Â
Device <18:3E:EF:CF:E9:82> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
A WiFi device <18:3E:EF:CF:E9:82> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
19.01.2021 22:52:48   Info   WIFI  Â
Device <1E:D6:36:44:1E:44> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
A WiFi device <1E:D6:36:44:1E:44> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
19.01.2021 22:50:10   Info   WIFI  Â
19.01.2021 22:48:24   Info   WIFI  Â
A WiFi device <1E:D6:36:44:1E:44> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
19.01.2021 22:47:05   Info   SYS  Â
01.01.2013 01:00:58   Info   SYS  Â
01.01.2013 01:00:54   Info   PPPOE  Â
01.01.2013 01:00:49   Info   PPPOE  Â
01.01.2013 01:00:47   Info   PPPOE  Â
01.01.2013 01:00:42   Info   PPPOE  Â
01.01.2013 01:00:40   Info   PPPOE  Â
01.01.2013 01:00:37   Info   WIFI  Â
01.01.2013 01:00:34   Info   WIFI  Â
Channel: (40/52) Channel Hopping initiated/Manually initiated
01.01.2013 01:00:33   Info   PPPOE  Â
01.01.2013 01:00:31   Info   PPPOE  Â
01.01.2013 01:00:27   Info   WIFI  Â
01.01.2013 01:00:27   Info   DHCPC  Â
01.01.2013 01:00:23   Info   DHCPC  Â
01.01.2013 01:00:22   Info   WETH  Â
01.01.2013 01:00:14   Debug   DNS  Â
19.01.2021 22:41:19   Info   WIFI  Â
Channel: (6/11) Channel Hopping initiated/Manually initiated
19.01.2021 22:36:55   Info   WIFI  Â
Device <64:A2:F9:4C:24:26> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
19.01.2021 22:34:39   Info   WIFI  Â
Device <8C:85:90:37:3E:DB> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV])
A WiFi device <8C:85:90:37:3E:DB> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_VIDEO_5G])
19.01.2021 22:34:11   Debug   DNS  Â
DNS name resolution failure (gtypwggxyco)
DNS name resolution failure (lodkeshorvq)
DNS name resolution failure (yvycpqs)
19.01.2021 22:34:10   Debug   DNS  Â
DNS name resolution failure (nsodsshyghlafzt)
DNS name resolution failure (wwbiaycrjdopamt)
DNS name resolution failure (wiwtytjudkhjyv)
Â
Help would be much appreciated. Thank you.
