Issues with 2.4 GHz signal, devices lose connection and cannot reconnect
  • 8 March 2024
  • 26 reacties
  • 163 keer bekeken
I have 2 devices (Philips TV & DELL Laptop) at home which only connects to 2.4GHz signal. And the problem now is, at random times in a day both the said devices disconnect from WiFi and wont connect for certain amount of time (hours in somecases) no matter what I try. I have to wait for the issue to fix by itself and then only I can connect my devices again. My devices are able to detect the wifi signal, but when trying to make connection it shows “Couldn’t connect, please try again”.
Question 1: Is there a way for me to check if 2.4GHz signal is up and running?
Question 2: Is there a possibility to turn off 2.4GHz signal? so that I can check if my devices operate on 5GHz signal?
Beste antwoord door Sanne van KPN 17 March 2024, 15:24
26 reacties
Badge +17
The buttons ‘Toepassen’ will always be there, that doesn't necessarily mean that Wifi5 or Wifi6 are off or not active. 🙂 One of them is always active.
