Mijn V12 modem loopt regelmatig vast
  • 30 August 2021
  • 148 keer bekeken
Hallo KPN,  V12 modem loopt vast, in de log staat dat “WLAN has been deactivated”  en vaak een verbinding opbouwen met een centrale server “TR-069 connectivity to (hengelo0.cust.kpn.net) has been closed”.
Wat is de reden dat het Wifi van de V12-modem wel blijft werken maar het bekabelde interne netwerk dan hangt?
Groet, Thorwald
Date/Time Severity Module Message
30.08.2021 13:03:56 Info SYS
Modem login was successful
30.08.2021 12:11:39 Info SYS
30.08.2021 12:11:37 Info SYS
TR-069 connectivity to (hengelo0.cust.kpn.net) has been initiated
30.08.2021 11:11:38 Info SYS
30.08.2021 11:11:36 Info SYS
30.08.2021 11:07:14 Info WIFI
Channel: (1/6) Channel Hopping initiated/Manually initiated
30.08.2021 10:11:37 Info SYS
30.08.2021 10:11:35 Info SYS
30.08.2021 09:11:36 Info SYS
30.08.2021 09:11:34 Info SYS
30.08.2021 08:22:32 Info WIFI
Channel: (6/1) Channel Hopping initiated/Manually initiated
30.08.2021 08:11:36 Info SYS
30.08.2021 08:11:33 Info SYS
30.08.2021 07:11:35 Info SYS
30.08.2021 07:11:32 Info SYS
30.08.2021 06:11:34 Info SYS
30.08.2021 06:11:31 Info SYS
30.08.2021 05:11:33 Info SYS
30.08.2021 05:11:30 Info SYS
30.08.2021 04:11:32 Info SYS
30.08.2021 04:11:29 Info SYS
30.08.2021 03:11:31 Info SYS
30.08.2021 03:11:28 Info SYS
30.08.2021 02:11:30 Info SYS
30.08.2021 02:11:27 Info SYS
30.08.2021 01:11:29 Info SYS
30.08.2021 01:11:26 Info SYS
30.08.2021 00:11:28 Info SYS
30.08.2021 00:11:25 Info SYS
29.08.2021 23:11:27 Info SYS
29.08.2021 23:11:24 Info SYS
29.08.2021 22:11:26 Info SYS
29.08.2021 22:11:23 Info SYS
29.08.2021 21:11:25 Info SYS
29.08.2021 21:11:22 Info SYS
29.08.2021 20:11:24 Info SYS
29.08.2021 20:11:21 Info SYS
29.08.2021 19:11:23 Info SYS
29.08.2021 19:11:20 Info SYS
29.08.2021 19:10:01 Info WIFI
29.08.2021 18:21:29 Info WIFI
Channel: (11/1) Channel Hopping initiated/Manually initiated
29.08.2021 18:11:21 Info SYS
29.08.2021 18:11:19 Info SYS
29.08.2021 18:06:23 Info WIFI
Channel: (6/11) Channel Hopping initiated/Manually initiated
29.08.2021 17:11:20 Info SYS
29.08.2021 17:11:18 Info SYS
29.08.2021 16:11:19 Info SYS
29.08.2021 16:11:17 Info SYS
29.08.2021 15:11:18 Info SYS
29.08.2021 15:11:16 Info SYS
29.08.2021 14:11:17 Info SYS
29.08.2021 14:11:15 Info SYS
29.08.2021 13:55:02 Info WIFI
29.08.2021 13:35:57 Info WIFI
29.08.2021 13:11:16 Info SYS
29.08.2021 13:11:14 Info SYS
29.08.2021 12:11:15 Info SYS
29.08.2021 12:11:13 Info SYS
29.08.2021 11:11:15 Info SYS
29.08.2021 11:11:11 Info SYS
01.01.2013 01:01:46 Info PPPOE
PPPoE connection successfully established with user credentials.
01.01.2013 01:01:45 Info PPPOE
01.01.2013 01:01:45 Info DHCPC
The WAN DHCP client IP address 10.162.226.88
01.01.2013 01:01:39 Info DHCPC
WAN DHCP client (1) started
01.01.2013 01:01:38 Info XDSL
VDSL connectivity is up port 1
01.01.2013 01:00:30 Info UPNP
UPnP functionality has been activated
01.01.2013 01:00:28 Info LETH
An Ethernet port is now connected (3/1000/FULL)
An Ethernet port is now connected (2/1000/FULL)
An Ethernet port is now connected (1/1000/FULL)
01.01.2013 01:00:18 Info DHCPS
The LAN DHCP Server is active
01.01.2013 01:00:18 Info WIFI
WLAN has been deactivated (.) (band : 5GHz).
WLAN has been deactivated (.) (band : 2.4GHz).
WLAN has been deactivated (KPN Fon) (band : 2.4GHz).
WLAN has been activated (GAST5G-WW-welkomwelkom) (band : 5GHz).
WLAN has been activated (gast-WW-welkomwelkom) (band : 2.4GHz).
WLAN has been activated (KPNCD7076) (band : 5GHz).
WLAN has been activated (KPNCD7076) (band : 2.4GHz).
Beste antwoord door RBxx 30 August 2021, 18:38
2 reacties
Hallo @Thorr eerst even een misverstand wegwerken, een V12 bestaat niet, het is een BOX12.
Gebruik je glas of koper?
Indien glas, heb je de glaskast al eens minimaal 2 minuten van de stroom gehad en daarna de BOX12 een complete fabrieksreset gegeven?
Indien koper alleen de BOX12 eens een complete fabrieksreset geven.
Succes.
Badge +21
Hallo @Thorr , de door jou genoemde meldingen in de logfile zien er niet verontrustend uit. Het zijn allemaal “Info” meldingen en niets zwaarder. Ik zie deze hier ook. De TR-069 meldingen geven aan dat de Box 12 één keer per uur even naar huis ‘belt’. Dit moet te maken hebben met het remote beheer van KPN. De WLAN meldingen maken deel uit van het opstartproces, jouw Box 12 is waarschijnlijk net opgestart. Heb jij net zoals ik KPN Experia of SuperWifi? Dan zal bij jou de wifi op de Box 12 ook uit staan.
Hebben de suggesties van @JanD geholpen?
