Good evening,
I restarted my modem and when I turned it on again only the power light is blinking and nothing more, I can’t even find my WiFi. What I can do?
box 12.
Beste antwoord door Shyrin van KPN
Bekijk origineelGood evening,
box 12.
Bekijk origineelHi
I understand you don't have any services. That ain't nice. :( You already restarted your modem, but without succes. Have also tried to reset the modem? There's a litte pinhole on the back where you can reset the modem with a paperclip or something. If that doesn't work, will you fill in your profile so I can take a look at your line.
It didn’t work, I already filled it in ☺️
Hi
I already filled everything in and restarting the modem didn’t work
I'm sorry to hear that the restart didn't work. I will send you a new modem: you can pick it up at a PostNL servicepoint, at this moment this is the fastest way to get a new one. You will receive a confirmation by SMS and I have send you a direct message with information where you can pick up the new modem. Will you let us know if replacing the modem is the solution?
Yes, everything works now! Thank you
