Network registration failed
  • 29 December 2020
  • 211 keer bekeken
Dear all,
I came to the Netherlands last year with an oversea sim card. Initially, I choosed KPN as the carrier, and it worked for a few months. However, I could not connect to it later. Every time I selected KPN, it said ‘Network registration failed’. I cannot use this oversea sim card in the Netherlands now. Does anyone know where the problem is, and how I can fix it?
Thanks in advance.
Beste antwoord door Erwin van KPN 7 January 2021, 11:49
Hi @michaellxli . Welcome to the forum.
Who is your provider?
China Unicom
Do you know if they have a deal with KPN to provide signal in the Netherlands? Have you tried other ISP's in the list?
I think they have because it worked for the first three months and it was carried by KPN. I tried vodafone and T-mobile but none of them is successfully connected.
I am afraid you wil have to contact your own provider and ask them for a solution.
