Subscription cancellation
  • 28 November 2020
  • 1 reactie
  • 50 keer bekeken
Dear KPN-forum,
due to myself leaving the country I cancelled my subscription a couple of weeks ago in one of KPN’s shops. However, I have yet to receive a confirmation of the cancelation.
I already sent router and receiver back as I, recently before cancelling everything, switched from TV & Internet to solely Internet. Hence, I already received a parcel with an “Antwoordnummer” and I was told to simply put everything in there (after I canceled everything in the shop).
Is it normal that the confirmation takes so long? Further, as I no longer live in the Netherlands I won’t be able to take note from it if they send it as a letter.
Thank you very much in advance!
1 reactie
Badge +13
Hi @Viktoria
Normally you should recieve a confirmation right away, I'd like to dubbel check if your subscripton is actually cancelled. Please fill in your profile with your zipcode and housenumber so I can go to work for you.
