WiFi werkt niet [ENG]
  • 25 March 2020
  • 19 keer bekeken
Hello good evening
actually I am a internet user of kpn
but unfortunately my WiFi connection isn’t work
could help me to solve this probl
*Admin: afgesplitst en een eigen topic voor vraag aangemaakt
Beste antwoord door Susan_ 28 March 2020, 11:47
2 reacties
Badge +21
Hi @Emon, welkom to our Forum and thanks for your message!
It is of course not nice that your WiFi does not work, especially in these times. Can you indicate whether it is only WiFi, or also wired internet and / or television? Can you also check which lights are lit on your Experia Box, and in which color? It can sometimes help to restart (power off, de-energize and power on) your Experia Box or reset it.
If all this has not helped, then I will gladly help you. Do you want to complete your Forum profile with name, zip code + house number and customer number and give me a sign you did?
Badge +21
@Emon, I have had no response. Can I still help you with this or is your problem already solved?
