Hello, I have the all-1 prepaid bundle unlimited internet and 30min calls but I cannot make any calls inside the Netherlands. Please could you fix this for me?
Bekijk origineelHello, I have the all-1 prepaid bundle unlimited internet and 30min calls but I cannot make any calls inside the Netherlands. Please could you fix this for me?
Bekijk origineelHi,
Are you sure the bundle is even active and if so, that you still have un-used min in your bundle?
You could check with the kpn prepaid app, if you dont have, send a text message to 1266 with the text SALDO
You will get then a message back with your remaining balance and active bundles.
Hi @misja20 yes and thanks for the information
This is what I see and receive:
Hi
Weird u have indeed enough units left to be able to call.
U can use the units only to call dutch phone numbers and not to other (eu) country’s so if thats not the case, there is indeed something wrong.
Best is, if u add your 06 nr and simcard number, under your profile, section called Persoonlijke opmerkingen
So a mod can help you.
Edit: Oh nvm a mod already responded to you.
