Hi
I bought a simcart to use in switzerland and the shop assistant told me that i can activate it through kpn prepaid app.
But it is not working.
What can i do about it?
Thank you
Bekijk origineelHi
Thank you
Bekijk origineelHi
Hi Marcia
Thanks for reply. I added the phone number.
Best
Thanks for the number
For this I will need some more information.
Could you add your postcode,housenumber and last name to your profile?
Hi
I added all the info you asked.
Best
Are you still in the Netherlands?
It must be activated by placing a call (with connection). But for that you must be connected to the KPN network in the Netherlands.
After that you can pair it in the app.
Thanks
