My sim card was brought to me overseas by my spouse. It is not working and we called customer service. They said they did their part and it will be ok in 5 minutes. The only thing that works is that I received SMS from KPN. I can't receive calls or make calls despite I have the credit. This is very important as I am relocating to Netherlands and I need a working number prior my move. Can we help please ?Â
Hi
Can you please update your profiel and give me a heads up if you’ve done so? I need the mobile phone number and the sim card number!
Hi Maja please find the relevant info and let me know if it is ok.Â
Mobile: ***********
Â
Greetings, Vlasis
*admin: removed phone nr. because of privacy reasons
HiÂ
Just in case, I transferred the ‘Bonus credit’ to the ‘Mainaccount’ of the card. Could you please try and make a phonecall? I hope it works!Â
Â
Sorry,Â
Bonus credit kan only be used within the Netherlands.
Outside the Netherlands you need at least some paid credit, minimal € 5. Beside that you can use the phone with a ‘bundel’. You can pay bundels from the normal paid credit. All bundels have a calling code to activate.
OUTSIDE the E.U. you can only use PAID BELTEGOED.!
To buy BELTEGOED you can use this kpn page:
https://www.kpn.com/prepaid/opwaarderen.htm
The bundels and their codes:
HiÂ
Â
Hi Lisa. thanks for looking into my matter. I can receive calls but I cannot make any. Currently I am in UAE and not EU which will be the case in few weeks from now.Â
Groetjes, Vlasis
Hi Thomas, I can receive calls but I cannot make any. It is not a problem now, but when I am in EU it will have to work! Thanks for checking.Â
Groetjes, Vlasis
I am not sure why it's not working. It has happened before that it's not working in the UAE. I don't know what the reason was, to be honest.. When are you back in the EU? It's possible that its working then, because I don't see why it shouldn't work!
This topic is now under Mobiele Abonnementen. But it should be under Prepaid.
@KaloÂ
Did you try to connect by hand with another provider?
@KaloÂ
No,  but I can receive calls and that is all that matters for me now. I have other numbers to make calls alternatively. I will deal with the issue in NL if it persists.
