*afgesplitst en eigen topic voor je vraag aangemaakt
Bekijk origineelBeste antwoord door Alex van KPN
Bekijk origineelMy printer is not working correctly. I feel that it is due to the printer settings. How can I find out how they should be set. When I print a list of items, 1 page, it prints on the bottom of the first page the first line of the list and prints on the second page 1 item. Nothing printed on the in-between items on the list.??? looking for a printer repair, help.
Â
Â
Hi N,Â
You should try a local repair shop or call the manufacturer. You do have a 2-year warranty on the printer. Printer repair usually isn't worth the time and money, printers nowadays are quite cheap. Depends on the printer of course.Â
