In fact, I connected my new TV with Ethernet cable to LAN port of Experia v10. Connection was established and worked well. I was able to navigate and watch YouTube videos. But after switching OFF and then again switching ON the TV - internet connection was lost on TV and it ask again to establish new connection. Despite that cable was still plugged in Experia v10, and in settings of Experia v10 I can see that TV is detected in network and DHCP IP address was still assigned to the TV. And then it is not possible to make new connection to the internet from TV until full reinstall of TV settings. After reinstall of TV settings, the problem still the same - first connection is successful, but after switching OFF/ON the TV it is again not possible to connect to the internet. Same behaviour observed with WiFi connection to Experia v10, not only with Ethernet cable.
Then I tried to repeat same steps with the WiFi connection from TV to my smartphone as a hotspot and it was as expected - TV was still connected to network even after switching OFF/ON. So problem observed only with router Experia v10.
Where can be the issue? Why does the TV always lost the connection after switching OFF with Experia v10?
Thank you in advance for any tip.
Beste antwoord door Myke
