Router (Box 12) keeps restarting
  • 26 February 2024
  • 20 keer bekeken
Got KPN fiber recently and the router keeps resetting every couple of minutes. I reset the router and even tried a different power outlet, but it keeps happening. Any idea what it could be?
Beste antwoord door Jeroen van KPN 28 February 2024, 10:41
2 reacties
Badge +19
Hello @Stefandj, that is really annoying when you internet restarts every couple of minutes. If you tested with a different power supply, i think it is save to say that is not the problem.
I suggest you contact the customer department. An agent can then do a fiberline measurement to see where the problem lies in your connection.
The new router isn't restarting anymore, but there are still multiple times a day when the internet connection drops without the router restarting. All the lights are green, but the internet drops for like 2 or 3 minutes each time
