Can't top up prepaid phone, I only have a credit card
  • 29 July 2022
  • 52 reacties
  • 561 keer bekeken
Reputatie 1
First of all, sorry for raising the question in English.
I have a prepaid KPN SIM which I have been using for a couple of years now.
I am struggling to top up so I can keep using the number. The app won’t load the payments page, so I tried https://www.kpn.com/prepaid/opwaarderen.
On the opwaarderen webpage, I try to pay by credit card but it says “U kunt geen gebruik maken van eenvoudig betalen omdat de limiet bereikt is. U kunt nog wel betalen via iDEAL”.
I have tried all sorts of amounts but the webpage keeps raising the same problem.
Unfortunately I do not have iDEAL or a Paypal account and I rely on the credit card functionality.
Would you be able to advise?
Thanks
52 reacties
Badge +30
Hi @Dancarv have you tried topping up your simcard with your credit card since february? I am curious if it also works for you! Same for you @KnightOfCydonia, have you tried it again these past couple of months? Is it working as it should?
Hi @Marcia_.
Just tried to top up after your posting ... and for me it has worked now. Thank you so much! 😊
